HD6 parts needed |
Ferg12
Topic: HD6 parts neededPosted: 09 Dec 2023 at 4:58pm |
Where can i find parts to rebuild my starter solenoid.
A new wheel and contacts. The starter is a delco 113714-9846. Orginal i believe and its a 1959. It is the foot-push start Thanks |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42276 |
Posted: 09 Dec 2023 at 5:13pm |
If the type with the contact being mechanical contact of brass plate to close switch it might be something you make yourself . OR get a 24 V solonoid type later starter to replace your unit .
Search engine - Delco 113714-9846 starter motor parts . https://www.google.com/search?q=Delco+113714-9846+starter+motor+parts+.&sca_esv=589461267&rlz=1C1CHWA_enUS627US627&ei=ufN0ZYr7CumB0PEP7r256Ao&ved=0ahUKEwjKu7HfvIODAxXpADQIHe5eDq0Q4dUDCBA&uact=5&oq=Delco+113714-9846+starter+motor+parts+.&gs_lp=Egxnd3Mtd2l6LXNlcnAiJ0RlbGNvIDExMzcxNC05ODQ2IHN0YXJ0ZXIgbW90b3IgcGFydHMgLjIIEAAYgAQYogQyCBAAGIAEGKIEMggQABiABBiiBDIIEAAYgAQYogQyCBAAGIAEGKIESJXbAVDeG1jC1wFwAXgAkAEAmAGtAaABzheqAQQwLjIzuAEDyAEA-AEBwgIIEAAYiQUYogTiAwQYASBBiAYB&sclient=gws-wiz-serp |
Coke-in-MN
Thanks(1)
Posted: 09 Dec 2023 at 5:19pm |
If it has a solonoid on top of starter , many times one can reverse the contact wheel and the lug that makes contact . OR you replace the solonoid .
Checking WALMART online - they have the repair kit . I have found WALMART Online sells parts way cheaper than Amazon and have ordered parts from their suppliers . https://www.walmart.com/ip/New-Starter-Solenoid-Switch-Repair-Kit-Compatible-With-Delco-SDR6204-247-12003-Silver-stationary-contacts/1212351322?wmlspartner=wlpa&selectedSellerId=101126811 New Starter Solenoid Switch Repair Kit Compatible With Delco Sdr6204 247-12003 Silver stationary contactsEdited by Coke-in-MN - 09 Dec 2023 at 5:22pm |
Les Kerf
Posted: 10 Dec 2023 at 8:45am |
Thanks for the tip, lots of good stuff there
Edited by Les Kerf - 10 Dec 2023 at 8:47am |
Ferg12
Posted: 11 Dec 2023 at 1:59pm |
Ferg12
Posted: 12 Jan 2024 at 12:58pm |
So replying to this post i had.
Question for same hd6 dozer Can u ground out starter(hot side and ground side) to get dozer to turn over as long as batteries r up to charge? What should be voltage be at starter before and while grounding out? No generator. Thought solenoid contacts where bad but we replaced. |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11426 |
Posted: 13 Jan 2024 at 9:51am |
They have the stater solinoid for a AC CA for $12.94 and WD 45 for $13.90
Coke-in-MN
Posted: 14 Jan 2024 at 9:00am |
Looking at the picture in your other post - the starter is a mechanical engagement to advance the starter drive into ring gear . Jumping across the 2 terminals will engage just the motor section to run but not advance the starter drive to turn engine .
Ferg12
Posted: 14 Jan 2024 at 9:06am |
Ok
When we jump terminals the starter doesn't do anything. There is voltage there to hot side of solenoid because there is plenty of spark when jumping. Starter locked up? |
Codger
Posted: 14 Jan 2024 at 10:14am |
Could be, but the starter needs removed and sent into a competent shop for evaluation and/or repairs. Plethora of things come together to make the starter motor rotate and whether your problem is mechanical, or electrical in nature is hard to say from behind a computer screen.
That's All Folks!
Ferg12
Posted: 14 Jan 2024 at 11:33am |
Ok thanks
Codger
Posted: 14 Jan 2024 at 12:11pm |
Have you ensured the engine is not frozen, or locked up? Attempting to rotate an engine with the starter motor that is either tight, or frozen will take a starter motor out on short order.
That's All Folks!
Coke-in-MN
Posted: 14 Jan 2024 at 12:22pm |
Might be something as simple as brush contact with armature , bad brush springs or bad brushes . Chances of being locked in - well could be but if the arm to starter drive moves free , it would kind of rule that out .
DieselBumpkin
Posted: 30 Jan 2024 at 8:12pm |
Easy enough to remove the starter and turn over the engine 1/50 of a stroke with a crowbar. On my '58 HD6B with the 344ci Lanova cell Buda, if I take off the hydraulic pump, there's a spot on the crankshaft where I could turn it over if they made a 3" wide flat head screwdriver. Somebody made a screwdriver that big because I saw the pry marks. You could also check the no-load condition of the starter if you have it removed. Pull it and leave it wired. Have a helper watch and listen for the Bendix moving and the motor rotating. That should be enough to get you started. If you feel like blowing $400+ on a new Delco-Remy starter, I bought one a year ago, and it's as much of a beast as the old one. It's like a 15 year old welterweight beating up a 75 year old heavyweight. Almost as heavy and a lot stronger and faster. I wonder what they put in the feed anymore.
zonroy-2
Joined: 16 Dec 2024 Location: mission bc Can Points: 2 |
Posted: 02 Nov 2025 at 12:26pm |
i have two 24 volt starters from hd6 Buda 6000 and 7000 also have new rod and main bearings for same most likley the last ones out there if interested ???
Trevor
Joined: 03 Nov 2025 Location: Ohio, United St Points: 4 |
Posted: 03 Nov 2025 at 5:37pm |
I destroyed my radiator,how screwed am I?
Anyone have a radiator for a hd6g? |
