D series seat suspension
Kddrck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kddrck Quote  Post ReplyReply Direct Link To This Post Topic: D series seat suspension
    Posted: 09 Dec 2023 at 2:11pm
Friends:
Last year at the swap meet I saw a vendor selling refurbished seat suspensions for D series tractors. I would like to buy one. Does anyone know if he is on this forum, or have the contact info of someone who sells refurbished suspensions.?Thank you.
Edited by Kddrck - 09 Dec 2023 at 2:11pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 8:54am
Pretty easy to do yourself.  Hardest part is driving out the old rusted pins.  When everything is apart, I have my local fab shop make new pins and put new bushings in all the parts.  Pant and put back together, will be as good as new.  I have done several and have another one to do this winter.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 10:31am
How much do you have invested when you do it yourself?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 5:20pm
Been several years since I did one.  Shaft and bushings done by the fab shop and a new shock absorber are the only real expenses.  Just my time to take it apart and put it back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kddrck Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2023 at 5:11am
Thanks for the reply. DJS sells the pins and bushings. I think I’ll go ahead and tackle it myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2023 at 5:14am
Don't even try to remove those tiny roll pins. Lay the suspension on its side, supported solidly at each pivot pin with a piece of pipe and drive the pivot pin thru the pipe shearing off the roll pins. A big hammer and strong arm with solid and squared blocking works the best.
Edited by DrAllis - 11 Dec 2023 at 6:12am
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2023 at 11:08am
Saw a D 10 or 12 seat video on U tube the other day . May be of interest ? Been a while but I've done a couple D 15 seat rebuilds . They weren't ez pz with my skill set but I got them done . Good luck !
Edited by ACinSC - 11 Dec 2023 at 11:10am
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2023 at 10:37am
Just got done doing a suspension rebuild on my recently purchased D17 series one. Roll pins are a pita, but got those removed. 1/2 pins were rusted tight in several places, used some heat and they slide free. Puchased the bushings and replacment shock assembly from DJS. I made the pins from 1/2 cold rolled steel.  Overall a very good design! Good Luck, Mike
