Clogged sink drain hocus pokcis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Clogged sink drain hocus pokcis
    Posted: 08 Dec 2023 at 4:14pm
Got a sink drain that slows up about every 5 years- everyone trys to take the real grease out and put it in the dog food can , but over the years its happens- have a hand driven wire spool thing and it hit it about 12 foot from the basement floor- the guys that plumbed it had so many twists and turns,, didnt understand that but Im no plumber- just know its suppossed to be all down hill- so - is there any mixtures anyone has put together to disolve grease in pvc pipes?? Got dranno once and it didnt work,, looking for any home ade brues,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 4:25pm
A LOT of HOT, HOT water( like 2 sink fulls) and then MORE 'should' soften it up....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 4:36pm
Been Trying that ,,, but not that much,, good thinking
Edited by DougG - 08 Dec 2023 at 4:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 5:23pm
Doug, if you can access the pipe and there is no vent before clog, a jetter works well. They fit inside your line, attaches to garden hose, a rubber bladder expands to fit the pipe when water is turned on. It will unclog many drains. Has the pressure of garden hose plus some. Make sure you have it in the pipe and secured. HTH Tracy plus some
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 6:08pm
Ah,, very nice ! Thanks,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 6:55pm
Any cleaner like Drano has to reach the clog to be effective. A lot of times there is too much water backed up in the line before the clog. Some professionals have a self feeding jetter that will push through and clear the line. Being old and lazy I usually call the drain experts these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 7:23pm
Try something longer for a snake , say a electricians snake to break through , once you get beyond then boiling hot water .
 Other thing is to figure out about how far your present snake reaches and cut the pipe and glue in a T or Y so next time you can clean the line or use that expanding water plug to jet line .
 I have a 2" cast line about 30' long and it use to plug often , last time I used my pressure washer and a reverse flow jetting nozzle and ran through line as I put a cleanout just above where line enters floor .
 If you don't have time to glue in new fittings , cut line and use a Fernco coupling to rejoin ends of pipe after cleaning the line (rubber coupling with or without SS outer wrap .)
 As far as drain cleaning chemical most do not work on clogs , but if you get line open and figure where clog was you could block pipe inside and clear with chemical areas of pipe that now do not have water in them by plugging pipe off . BUT mechanical cleaning is best or jetting out with pressure washer
Edited by Coke-in-MN - 08 Dec 2023 at 7:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 9:50pm
When I worked for Roto Rooter they had a liquid concentrate that you only needed a quarter cup mixed with warm water. Once a month and worked really well on kitchen sink drains. They sell a roto Rooter brand at Menards but it is not concentrated.
2 types of drain cleaner,caustic acids or bacteria/enzymes . Caustic acids ,based on sulfuric acid that will dissolve hair clogs on contact, will also heat up when contacts water.
Bacteria and enzymes eat grease and gunk , more of a preventive maintenance than a drain opener.
My Spartan drain cleaning machine with a 1,1/2 cutter blade works best
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 11:21pm
The first one I can attest to as I have used it many times.  Success rate?  I'd say about 19 out of 20.
IF it's grease, I'd say try the last one, it sounds promising.
Pour 1/2 cup baking soda, followed by 1/2 cup vinegar down drain.
Plug drain and let sit for one hour.
Then, pour a pot of boiling water down drain. Repeat if necessary
This will clean out a lot of clogs so try it first before running to the store to buy a commercial drain opener.
or
Mix 1/2 cup table salt and 1/2 cup baking soda together, and pour down drain.
Let sit for about 30 minutes (or overnight if it’s a tough clog).
Follow with a pot of boiling water.
or
Salt + Borax + Vinegar Drain Cleaner
Pour 1/4 cup salt, followed 1/4 cup Borax down drain.
Pour 1/2 cup vinegar down.
Finish with a pot of boiling water.
Let sit for one hour or until it clears.
Run hot tap water to rinse any remaining solution down.
or
Dish Soap and Hot Water
Boil about two liters of water and mix in a few tablespoons of liquid dish soap.
Take this mixture and slowly pour down the sink.
This method may take a few tries, but it will work great on grease clogs because it is heating the grease back to a liquid so it can travel all the way out of the pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 5:58pm
I have a hose that is smaller diameter than most 1/4" air hoses and flexible enough to run down pipes which hooks onto pressure washer - the reverse jet nozzle cleans pipes well and I use to use a similar system for cleaning PYREX glass pipe that was used for acid drain lines .
 With PVC drain lines you have to be careful with hot solutions in the horizontal runs of pipe as they may sag from heat . This can also be a problem with using lye or other chemicals that create heat when mixed with water .
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 6:28pm
Baking soda and vinegar works for me.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 7:51pm
toilet stool plunger following the hot water has worked for me.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 9:25pm
Yeah tried that - now its really stopped up, was slow but now REAL slow - gonna have to get an auger I believe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 9:41am
Try one of the balloon attachments for garden hose - just get it down past vent line opening for it to work .
 As your pipe is PVC - cut in a cleanout in the drain line to make it easy the next time
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 9:06pm
Where in MO are you located Doug? Road trip? Send me a pm
Edited by Pat the Plumber CIL - 10 Dec 2023 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2023 at 6:01pm
Awe Im good Pat, this happens about every 5 years- Ill get it , this one is tough tho ! Last time I rented an auger from our hardware store-
This page was generated in 0.184 seconds.
