hydraulic pump on WD 45
J. Larsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J. Larsen Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic pump on WD 45
    Posted: 07 Dec 2023 at 2:07pm
I'm getting closer, I show 2 pics of the WD45 and the hydraulic lines as they currently exist.  Do I need to do 2 seperate posts and just put 1 picture on each post?
I'm trying to figure out how to get the lever on the left side to operate the 3 point.  Currently, the lever is inoperative, although it is hooked up to the linkage on the hyd. pump.  The way the 3 point works now is strictly with the control valve lever to the left hand of the seat.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 2:34pm
You need to close the valve by the corner of the battery box.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 8:09pm
to little of a picture for me very clear , dont know why its hooked to that valve by the seat  ,what    does the rod the rod on the pump hook to thats what turns the pump off and on the valve by the seat would only work when the pump is on  , the valve buy the seat has to return the oil back to tank or they will not go down unitl you put the pump in lower position and then let it down with the lever by the seat     .     it needs the hoses put back on the pump where they belong and get rid of that valve by the seat unless pipe like you aregoing to have a pair of remotes
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 10:44pm
That is a mess! I can't figure what they were trying to accomplish with all that. Factory setup would work the 3 point just fine.
