Anybody got one of these CARTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Anybody got one of these CARTS
    Posted: 06 Dec 2023 at 6:53pm
I bought one about 5 years ago to help my back... Dont have to bend over so much.. Lower to the ground and put parts on the table, then pump up to 36 inch height.. Also roll to the back of truck and same level as the tail gate.. I had to buy a second one after that.. Put news paper on when painting parts... Have a sheetmetal pan to set on it when using the plasma cutter... Cant do without them.. Use it every day............. But i think they were about half price back then !!
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 7:45pm
I have two but they are not near that light duty and both are electric. Both are on casters but too heavy if loaded to move without a machine. One is a "Southworth", (8K lift), the other an "American Lift", (1.250T lift).
That's All Folks!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 9:16pm
  Hey Steve,,,I'm not positive but think I have  seen something similar at Harbor Freight,,,,I was in Harbpr Freight today to get some more ,,,,(you guessed it) Clap,,grinding wheels,,,,LOL
  In case anyone needs some,,,Harbor Freight has the 4 1/2" 1/16" metal cutting wheels on SALE for a 10 pack for $4.99,,,,!!!!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 10:24am
Be aware, those cheap cutoff wheels shatter quite easily and I won't allow them in my shop.  The best I've found are the Walter brand.  They ain't cheap but will handle quite a degree of flex with out shattering.  We use them on a daily basis and I don't think I've ever had one shatter into shrapnel like the cheap ones tend to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 10:50am
I strongly second the Walter brand followed by Norton.  Both much more durable than those available mostly online.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 3:00pm
Have a cart similar but lot heavier , got when closing down plant I worked at .
Also picked up a pallet jack (battery powered lift) from floor to 40" or so and 3,000 lb lift . Was going to make a cycle lift from it but then bought a Harbor Freight one on sale .
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 10:40pm
The picture is a Harbor Freight add.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 9:51am
They have a lighter duty cart that is 500# rated... But i thought the heavier cart would be better in the long run.. I normally  only have 100# on the cart, but sometimes 3-400#.... thats about all i want to  mover around and put in the truck... anything bigger would go to the overhead hoist.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 3:05pm
I've got a commercial duty 1 I got several years ago at a consignment auction. Cost me $25.00. it works good for me.
