Pictures of Hydraulic Lines
J. Larsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J. Larsen Quote  Post ReplyReply Direct Link To This Post Topic: Pictures of Hydraulic Lines
    Posted: 06 Dec 2023 at 12:44pm
Here are the pictures of the plumbing coming off from the pump, to the 3 point control valve, and return to the bottom of the pump.
I think that the pictures are there, the first one is goofy, so ignore it, but the other 2 work, I think.  I have uploaded the files, but when I try to up load the pictures, It says to use the browse button to select an image.  I  don't see the browse button.
If there are pictures of the factory plumbing, that would be appreciated.
Thanks,
JL
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 3:35pm
Which tractor are you talking about???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 4:15pm
John, when you start a post and want to insert a photo, click on the Green Tree Icon at the top of your posting box.... That will take you to an INSERT PHOTO page... At the lower left of that page you will see a CHOOSE PHOTO box.. Click on that and it will open your Computer Desk Top and you and click on a photo file to upload ( assuming you are using a computer).... Then click UPLOAD box and you should be good...... NOTE... PHOTOS should be about 800 x 600 size.. Too large and they will not upload.
Edited by steve(ill) - 06 Dec 2023 at 4:16pm
