U or UC trans seal retainer/throw out shaft
Mfam8 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Topic: U or UC trans seal retainer/throw out shaft
    Posted: 04 Dec 2023 at 9:00am
I had pulled this for another customer, they ended up not needing it, thought I'd see if anyone is looking for one by chance. This is the front seal retainer for the transmission on the U and UC tractors, and it also serves as the pivot shaft for the clutch release bearing. They often break when engines are pulled and not supported evenly, or sometimes just from the years of service. Got a good one here as I said, 75.00 gets it to your door, shipping and everything. Just shoot me a private message here or follow up on this thread. I can send pictures via text or email if that helps anyone.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 9:28am
I have a 37 U and a 37 UC. The shifter on the UC is so sloppy it's hard to find and engage any gear. 4th gear is a real trick. My question is, will the trans cover, forks, shift rails and all, from U, that shifts so much nicer, fit right on  the UC? I know I will have to move/ajust/tweek the shift rod for operator comfort, that don't bother me. Just wondering if it's a quick swap and if so do you have one for sale?
Thanks
Leon B MO
