minor electrical SNAFFU
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: minor electrical SNAFFU
    Posted: 03 Dec 2023 at 1:43pm
A 'split' receptacle next door, tenant was still using the good half. Guess which one ?
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 2:00pm
Wow that doesn't look minor to me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 2:34pm
Ooooofa!  Not good! At least you're not replacing the house!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 4:46pm
did ya LICK your fingers before you pulled it out ??  Wink
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 5:04pm
Damn! How many space heaters were they trying to use?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 5:24pm
circuit breaker should have prevented any issue with too many heaters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 5:33pm
1500 watt IR heater was the load. The 'problem' is the receptacle is mounted horizontally, so every time he moves the extension cord ,the male end 'blade' opens the gap in the receptacles contacts. Over time, a real 'gap'..bzzzzz.poof. Won't trip breaker as not a 'short'
Located in old skool plaster walled cooler (part of MY old shop..), so  not a real fire hazard,luckily
Good news is I get some more free body work !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 9:19am
I think you dodged the bullet on that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 10:49am
well.... since I sold (gave away) the property 3 years ago...
not my property, not my problem.....
visited another neighbour and he was about to bury  a doorbell transformer IN THE WALL ! I showed him the receptacle and he quickly changed his idea !
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 2:01pm
Someone upstairs was taking care of you.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 8:41pm
And they breed.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 7:02am
15a outlet, 1800w heater Surge Load on Startup is right at that 15a and constant draw is right at 13a.  Lucky is all I could think as to Not Burning the whole place down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 2:03pm
except it’s a 1500w heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2023 at 2:33pm
My bad.
12.5a constant load.
Shock load is around 10-15% still close to max amps starting. +1.25 to 1.8a.   Added resistance from bad connection adds amps.
Edited by DMiller - 06 Dec 2023 at 2:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 8:36am
Finally , got #3 !!!
Old dryer, timer went on it..have 5 good 'old' timers in stock....
NONE will connect,all wrong style....
OK, put dryer roadside....gone in an hour.... !
Hopefully done with electrical problems now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 9:14am
back to the cloths line and sun shine ?? Wrong time of year for that !!  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 9:20am
actually dryer was a from neighbour along with working washer...I need ROOM in garage, not 1/2dead spare appliances....
