D-10 pivot bushing
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: D-10 pivot bushing
    Posted: 02 Dec 2023 at 2:07pm
Bout finished with son's D10 III rebuild & noticed front axle pivot bushing worn egg shaped & all the way through. Looks like it's welded in, can a shade tree like myself get this out? Just wondering I have no burning or welding equipment. Where can you order these from ?  Any help appreciated, thanks keith so. va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 3:11pm
IIRR they are tacked in from inside. Should be able to take a 4 1/2 grinder and get it out. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 3:47pm
Ok thanks, I'll try the grinder. How about getting a new one & how to install??
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2023 at 3:51pm
I've replace those bushings with a 3pt adapter bushing. Just find the one that is 7/8" ID.
AmericaLind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericaLind Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2023 at 1:21am
To replace the worn front axle pivot bushing on your D10 III without welding, try drilling and splitting the old bushing. Clean the area, then press in a new bushing. You can order replacement parts from local tractor supply stores or online retailers.
