D19 diesel radiator
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Topic: D19 diesel radiator
    Posted: 29 Nov 2023 at 6:54pm
In need of a D19 diesel radiator, does not have to be good, I have parts of one, I need the bottom tank, side frames and the fan shroud.Let me know what you have. Thanks...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 7:07pm
Gas or diesel should be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 7:26pm
Thanks Doc, I thought that to be the case, now not arguing but wasnt the diesel core thicker than the gas core? The reason I ask is I had a diesel radiator that the top tank came loose from the core, carried to rad. shop, for repair, they told me the core was bad, I seriously doubted that it was but I needed the tractor so I got a new core, I kept the old core, now I am repowering a D19 and need the radiator, carried the gas radiator to a different repair shop to have the thicker diesel core installed, they call and tell me that the bottom tank, and components won't work. Thoughts...... Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 8:59pm
There was an "early" radiator that had a very long neck and a shorter (D-17) height core. They were soon subbed up to the later taller radiator. The diesels should have had a thicker core but not sure they really did in the end. For sure they would interchange to fit in the same spot. Maybe A-C had two suppliers thru the 3 years they were built ?? I wouldn't be able to prove that (or not). AGCO parts does show diesel with a diff p/n, but like I say, near the end, why not the same for both?? cost couldn't have been that much diff compared to two different ones.
Edited by DrAllis - 29 Nov 2023 at 9:02pm
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 6:56am
I have a gas radiator. Leaks but the tin is nice.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 1:38pm
Lon sent you a PM. Thanks?
