7040 engine oil cooler reseal
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: 7040 engine oil cooler reseal
    Posted: 28 Nov 2023 at 2:01am
Oil cooler on my 7040 needs re-sealed, can the inner tubes be tapped out with a block of wood without damaging them, I don't have a press. First time messing with one of these, thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 2:48am
Yes. We always had a 4 x 4 block re-shaped to slide in and be the pusher against the cooler core.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 6:22pm
Doc what all is needed as far as parts to complete this job?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 6:55pm
O rings and gaskets. Not much involved here. The cooler o rings are specific as to water side or oil side of the cooler.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 8:10pm
I done this on my 7060 few years back. a search of my stuff might bring it up
I think the main thing is to put the o-rings in the right place
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 8:32pm
the block and cooler mating  surface must be squeaky clean with a non silicone gasket sealer. That is the biggest challenge we have had.
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 9:50pm
Assemble everything loosely, and don't tighten any bolts until it's all together on the engine. Then tighten them down a little at a time, working your way around from gasket to gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 9:13pm
Is it better to glue the gasket to the engine block or the cooler, on reassembly? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2023 at 8:06am
Don't know about better...I glued gasket to cooler
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2023 at 12:16pm
Thanks Steve, that's what I was leaning towards,Tbran mentioned having difficulty with this seal leaking, I didn't know if one was better than the other
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2023 at 7:39pm
I figured it may be harder to seal the slick aluminum over the cast iron block so I put the sealer there.
