Carb surge spring CA
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Carb surge spring CA
    Posted: 25 Nov 2023 at 11:00am
Ok guys n gals before I fire up the freshly rebuilt 125 every surge spring I’ve seen pulls it forward however the spring I have doesn’t appear correct so I’m wondering does the spring pull forward or should the spring pull towards the rear thank you. Dana
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2023 at 11:05am
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2023 at 11:19am
The right way is to hook the long end of the spring over the top manifold stud forward of center. Some have hooked it many other ways, all wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2023 at 2:24pm
Thank you!
                          Dana
