D-19 governor
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: D-19 governor
    Posted: 23 Nov 2023 at 4:08pm
i need to replace gasket on governor housing its leaking , i see its held in place by 3 bolts, is it a simple straightforward procedure or is there springs and internals i need to be careful with when removing?
Cowboy UP
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 4:58pm
Really simple,nothing to worry about falling out. Hardest part is unbolting the coil and moving it out of the way and the small oil line .
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2023 at 10:11pm
Pretty sure there are four bolts and one comes in from the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 12:49pm
so i will have to remove timing cover?
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2023 at 2:23pm
No just a bolt. You will see it.
This page was generated in 0.079 seconds.
