ac 7030 shift problems
glenn962 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote glenn962 Quote  Post ReplyReply Direct Link To This Post Topic: ac 7030 shift problems
    Posted: 23 Oct 2010 at 8:01pm
 I have a 7030 tractor that at first I couldn't put in 1 & Reverse , then 2&3 also wouldn't go into gear , But 4&5 still work along with high & low work fine. Any ideas befor I start  working on it ?
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 8:09pm
trying to remember.. does that have the side shift like the 7020?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 7:20am
Pull the floor board and then the shift cover.....you may have something broken in the shifter rails/forks and you do not want something to be eaten by turning gears.
