Allis chalmers 7000 |
Post Reply |
Gffarm
Bronze Level Joined: 18 Nov 2023 Location: Wisconsin Points: 3 |
Posted: 18 Nov 2023 at 4:25am |
Does my 7000 have to be in park to start? Had transmission cover off to fix issue, and now doesn't start. Any reason for this?
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20186 |
Nope. Safety switch on the clutch pedal (not easy to access) and one on the PTO lever, which you probably bumped with your body wrestling the cover on and off. Make sure the PTO lever is OFF.
Gffarm
Already checked safety switches, even tried arching the starter which stuck engaged, replaced starter arched again, same result
DrAllis
Well, if "jumping" at the starter with a screwdriver (to the 10gauge white wire) doesn't make it crank over, you have a starter issue or battery cables or batteries.
Post Reply | |
