190 d19 axle question
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Topic: 190 d19 axle question
    Posted: 14 Nov 2023 at 8:57am
Do the axle housings that bolt to the rear end housing are they the same and interchangeable between a 190 and a d19. Could you take a d19 high crop axles and bolt them on a 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 11:56am
They may have different part numbers, but they should bolt right on.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 3:24pm
If you plan on putting high crop drop housings on a row crop tractor you will need to flip differential in rear housing.
If you don't you will have 4/8 reverse gears and one/two foward.
Edited by Macon Rounds - 14 Nov 2023 at 3:25pm
