plow`reset |
Post Reply |
nella(Pa)
Orange Level Access Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3102 |
Posted: 12 Nov 2023 at 9:36am |
Which`automatic`type`reset`works`the`best`for`a`moldboard`plow?
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20186 |
Allis-Chalmers only had one design of auto reset, and it was hydraulic with a lot of linkage to the plow bottom. It was a good system and I have spent some time over the years using a 6-bottom on-land hitch. The negatives were six hydraulic cylinders and an accumulator to maintain. IH for example had a reset plow with big coil springs instead of hydraulic cylinders. They also had a good plow. I imagine it was less upkeep over the years.
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2227 |
I had an IH, think it was great, also had AC hyd worked good but a lot of mechanism
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 7076 |
I’ve only used two designs of moldboard plows, the IH auto-reset spring, and the old Oliver auto-reset hydraulic style. Both worked very good. I would give a slight advantage to the IH, just for the fact the spring reset was a tad quicker. For the quality of the plowed ground, the Oliver was better. One important tip when plowing with any style of auto-reset, is proper ground speed. Auto-reset’s are designed to reset immediately upon clearing the obstruction, in other words right on the back side of the rock(or whatever), not 3, 4, 5 feet after going over the rock, it there is unplowed ground showing, your ground speed is too fast. We plowed with an IH 856, 18.4 x 38 rears, low range 3rd gear TA forward, wide open throttle. We had the power to use 4th gear, but the quality of the plowing was poor.
nella(Pa)
many thanks for your replies Gentlemen
DrAllis
Oliver had the first hydraulic reset plow. It's break-back linkage was pretty simple and straightforward. The flaw was, the point of the plow share went deeper into the ground when it initially broke back. This is what A-C and IH tried doing (with success) with their uneven parallel linkage. As the bottom broke away, the shares point always kept raising, trying to get over the obstruction. This helped with the bottom re-entering the ground much quicker, not leaving those bald spots in the field. But, in order to do this, the plow became more complex and expensive. Pick your poison.
Edited by DrAllis - 13 Nov 2023 at 6:21am |
Tom59
Bronze Level Joined: 27 Feb 2021 Location: Lebanon Tenness Points: 150 |
I got a Ford 150 spring auto reset, 3-16 plow. It was built by Oliver/White for Ford. It just got two big coil springs for each plow bottom. Simple design. I brought it at an estate auction back in 1999 and they also sold a Ford 7000 tractor also and that was his only big tractor so I assume it was brought with that tractor.
DanielW
Bronze Level Joined: 19 Sep 2022 Location: Ontario Points: 157 |
Hard to beat the spring reset on the Scandinavian style plows. The Kvernelands are particularly good - night and day difference over the old school spring resets you'd get on the North American plows like the IH's, etc.
Not that the old ones were particularly bad, it's just that the Kvernelands, Overums, etc. are superb for both consistent pressure and being able to take a s***-kicking. In some of our rocky fields at our Northern farm the boards seem to spend more time out of the ground than in. We have many places where bedrock shoals hover just a few inches below the surface. We used to go through a lot of plows, and behind one of our machine sheds is our plow graveyard with IH's, Fords, Whites, and a few others. Then we bought a Kverneland with the coil resets - that plow is still working just dandy, and we plow a lot more ground now than we used to. I prefer the coil-spring style resets over the leaf-springs: The leaf-springs have slightly more consistent pressure and linear spring characteristics, but the coils allow the board to come back much farther and are better for really rocky/abusive ground. We found the best of the North-American style plows were the IH 720's. Tried a couple of hydraulic resets, they didn't stick around long. They might have been ok in better ground where you'd only have the occasional trip, and where it was only one board at a time. When you trip frequently or come suddenly across bedrock and multiple boards trip at once, however, the small lines to the accumulator can't handle the flow volume as well and it doesn't react as well. Plus you have an accumulator to charge that requires a high-pressure nitrogen tank and special fill adapters/gauges. We never had a Massey with hydraulic reset, but I always heard they plowed excellent but had the worst hydraulic resets: Apparently the accumulators weren't large enough to handle the volume from a several boards tripping at once, and you'd blow the bladder out. Spring resets work just dandy - no idea why we (or anyone) added the unnecessary complication of hydraulics.
Edited by DanielW - 13 Nov 2023 at 10:10am |
Post Reply | |
