differance in d17 gas lube systems
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: differance in d17 gas lube systems
    Posted: 11 Nov 2023 at 11:13pm
what are the differance from series 1 to series 4 engine lube systems the pipeing on my two parts tractor engines are alot differant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 2:16am
Knowledge Base near the bottom of page 1.   WD-45 full-flow oiling conversion
Edited by DrAllis - 12 Nov 2023 at 2:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 9:04am
The "OLD STYLE" uses the Bypass filter with the mason jar thread.. Same as the B,C,CA,WD... etc......... Later in the "D" series they switched to the automotive PH8 full flow filter..( some had the old, then later they had the NEW).. it would have a much larger tube ( maybe 3/8 inch??) coming off the filter housing and screwed into the side of the engine block..
You can not interchange the filters or housings.. Things are different inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 9:07am
