d17 series IV 3pt problem
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: d17 series IV 3pt problem
    Posted: 11 Nov 2023 at 10:44pm
i bought a d17 series 4 and cant get the 3point to work ive taken all the linkage apart and freed it up but still can not get the arms to go down.. any thoughts .. thanks
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 7:10am
Since you already have all the linkage free, you have completed the first step. Place both traction booster and depth control levers all the way forward. From the rear, take the cap off the hydraulic spool closest to the fender and with a punch gently tap in the spool. The arms will drop.
JoshuaJames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshuaJames Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 7:39am
These tractors typically need quite a bit of weight to lower the lift arms in my experience. None of my allis chalmers lower without help. Unlike my fords that drop to the ground with a push of a lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 8:54am
My A-C 3 pts all drop on their own weight
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshuaJames Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 11:39am
None of mine have factory 3 point so that may be my issue with them needing added weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2023 at 1:33pm
You're both correct.  Many series 4 D-17's thru 7000 tractors need someone standing on the 3-point to get them down, with the engine running and/or with COLD hydraulic oil. Many others will drop on their own weight, especially with the engine shut OFF. No two tractors exactly the same, but YES, some need a little weight on them at times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 3:14am
i will try that today thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 3:15am
it still wont go down i even tried putting the skidster bucket on them and pushing down... nothing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 4:48am
Next step. These arms have been stuck UP for years. Disconnect one of the connections to the lift arm hydraulic cylinders. I don't care which one, but disconnect completely one of the hoses or lines. Engine off. Push down with your skidloader again. Be prepared for oil to squirt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2023 at 12:41am
i got it! thanks guys! got the hyd spool leaking now lol but at least the arms work
