Injectors 2900 engine
Bijou605 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bijou605 Quote  Post ReplyReply Direct Link To This Post Topic: Injectors 2900 engine
    Posted: 06 Nov 2023 at 1:07pm
I just swapped out an engine from a M2 combine to a 545B payloader and used the injection pump and injectors from the 545B engine and now the injectors leak compression around them, both engines had the copper injector sleeves, my question is are there supposed to be copper washers on the tips of the injectors. The original injectors out of the M2 engine did not have any and also the 545B did not have them. What am I missing?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2023 at 3:07pm
No washers with copper tube heads. The end of injector is tapered where it seals. You either didn't get the bottom of injector holes in head clean, ends of injectors have carbon buildup holding them up, or your bolts are slightly too long not clamping down quite enough. Never wire wheel the nozzle tip though, it will ruin it by damaging the small holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2023 at 3:40pm
My first thought was un-even tightening of the bolts causing the injector to cock in the bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bijou605 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2023 at 6:56pm
Got it figured out bolt's same length in both engines but holders on M2 engine sit higher & holes in head are not drilled as deep as 545B engine had to use a couple thin flat washers & lock washer to take up the space the bolts bottomed out but still torqued.
Thanks
