Allis B and Howard Rotovator
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Topic: Allis B and Howard Rotovator
    Posted: 05 Nov 2023 at 2:50pm
B guys,
Has anyone used  the small Howard Rotovator behind their B? There is a model that can run behind a Farmall Cub. If you have, how did it work and how did you lift it at the end os a row. Thanks
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 3:59pm
Link to a Video for reference:
https://www.youtube.com/watch?v=HpcPeuFJzeQ
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 4:04pm
apparently your tractor does not have a 3 point hitch.. Do you have hydraulics ?  Any type of lift arms ?   Rock shaft and cylinder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 5:10pm
Steve, you are correct. My '39 B is bare bones, it has a handlift cultivator. thought about addng a rockshaft and hydraulic cyclinder. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 5:58pm
the rotovator would be very heavy to rig up a hand lift... I would think you need to look into a rock shaft and cylinder first .... By mounting a 3 x 3 angle between the final drive cases on the drawbar bolt point, you could attach a couple 3 point arms off a 8N ford ( sold at Farm Store) ... and use your rock shaft to do the lifting.
You can BUY  a couple different types of 3 point hitches.. Or make a simple one of your own.. Here is a photo i saw on the internet a few years ago to give you an idea.
Edited by steve(ill) - 05 Nov 2023 at 6:07pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 6:34pm
B runs way too fast in 1st gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 6:54pm
Ok thanks
