Gleaner F3 hydraulic pump / unloader jackshaft
slowzuki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slowzuki Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F3 hydraulic pump / unloader jackshaft
    Posted: 05 Nov 2023 at 7:52am
Inner bearing on front pto left go, that is driven from engine below the fan. It sure looks like I need to unthread the pulley in the limited space up there to get the shaft out.
Any tips or tricks?
Edited by slowzuki - 05 Nov 2023 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote slowzuki Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 9:44am
Was able to remove the nut, still working on the pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 12:49pm
Jam a bar thru the pulley spokes and a big pipe wrench on the shaft. Make sure you go the correct way.
mnjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnjoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 7:19pm
I wrapped a chain around the pulley that drives the pump and used a come-a-long  anchored to the rear axle. Make sure you are turning it the right way. Pipe wrench didn't work for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slowzuki Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 8:30pm
I ended up making a 3 finger socket to turn the pulley. Big pipe wrench on that worked well. Just tedious. Unfortunately being Sunday, the only bearing I had on the shelf was a greasable one with setscrew lock so I’ll be back into it before long.
