21" tool box
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 21" tool box
    Posted: 04 Nov 2023 at 10:53pm
when did they start putting the 21 inch long tool box othe d 17 tractor the series 4 parts tractor that i got has that.  it will  hold  somthing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2023 at 11:02pm
My series 3 had the long tool box, only on the right side instead of the left. It will hold the official wheel tread wrenches it is that long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2023 at 7:27pm
my series 1 is going to get that long tool box
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2023 at 5:16pm
My series 1 had one when I purchased it, bottom was pretty rusted out so I replaced it with a new one. Not sure if the long box came from the factory on a series 1 but it fit perfect. And yes, it holds a lot of tools.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 8:00am
All right, anyone ever put one of these on a WD or 45? Probably be kind of in the way I would guess. Bigger toolbox would be nice on these old girls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 8:05am
If you located the rear edge of the box in the same place and extended the extra length forward, you'd be alright. I think the lift arm latch comes kinda close when the arms are fully up as it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 8:16am
I could check out the lift-arm/latch thing here in just a bit. I only have the one 21" box and it's rusted on the 17b pretty good. Maybe remove it and hold it up for comparison. If I wind up keeping this series 3, which is a pretty good possibility, it will need a new box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2023 at 9:05am
Yesterday I checked this out. Raised the plow fully up, measured the three inches on each end, plenty of room. Now I just need to procure a new box or two!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2023 at 11:04pm
it would be nice looking mounted on the frame rail of a wd
