6080 3 point hitch lift arm leaking.
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: 6080 3 point hitch lift arm leaking.
    Posted: 01 Nov 2023 at 9:24pm
This seems pretty straight forward. Loosen cap screw, remove remove arm, pull thrust spacer, pull old lip seal, install new lip seal, spacer, and torque to 108 ft/lbs.
Do I need to drain hydraulic fluid?
Anything I am missing or need to check while I am in there?
Thanks!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2023 at 8:00am
Don't know the answer but will be watching. Mine don't leak but it never hurts to know these things when something pops up!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2023 at 8:46am
Yes sir! Learning as I go!
With the help of all these nice folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2023 at 10:47pm
Which ram does your 6080 have
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2023 at 6:21am
Mike, how do I find that out? Sn: 60803097.
