Battery connections
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Topic: Battery connections
    Posted: 01 Nov 2023 at 8:52am
We have an HD 16 bulldozer, What is the property battery connections? New batteries and starter, doesn't seem to have enough battery to turn over properly, Thinking maybe the hired help have cables connected wrong.
Edited by Steve Bright - 01 Nov 2023 at 8:52am
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 9:01am
That is a 24VDC starting system. If the starter, or starting system is known good, it is probably interconnected wrong. Basically you run one battery positive lead to the starter solenoid and this battery's negative post to the positive post of the second battery. The second battery's negative post would then normally attach to your "Master" disconnect switch, (if tractor has one) or directly to the frame, or steel structure of the machine. The batteries are now in "series" and the voltage is additive meaning two 12VDC batteries in series output 24VDC.
If you have an older tractor with a generator rather than an alternator, it is very likely the system is positive ground. Basically you reverse the battery connections as stated running the positive battery lead of the first battery to the tractor frame and the negative lead to the master disconnect switch, or starter solenoid.
Edited by Codger - 01 Nov 2023 at 9:46am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 9:09am
Don't know that tractor so asking is it 12volt system? Using 12V batteries in parallel or 6V in series? Is it negative ground? 12V batteries have both positive hooked to solenoid and negatives to ground( neg ground system) 6V in series neg ground would have neg to ground on first battery with that batteries positive hooked to second batteries negative then second batteries positive hooked to starter.
I type slow...Codger probably has better info than I
Edited by SteveM C/IL - 01 Nov 2023 at 9:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 9:24am
Thank you Codger, Ours is a 24VDC system, I will check it out after lunch today. I really appreciate your response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 9:49am
Sorry if I was confusing in my response. I typed 24VDC rather than 12VDC then changed direction I was typing in. Didn't proofread before posting but have corrected the post so now accurate.
That's All Folks!
This page was generated in 0.252 seconds.
