MK II 3700 irragation motor
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: MK II 3700 irragation motor
    Posted: 29 Oct 2023 at 6:43pm
Would this motor have a good crank for pulling.
It was an irragation engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 9:00pm
3750 engine has the counterbalanced crankshaft if that's what you're looking for. All counterbalanced crankshafts use a fluid/viscous crank pulley type damper, not a rubber pulley damper. So, they are easy to identify by simply looking at the damper, without tearing the engine apart to verify.
Edited by DrAllis - 30 Oct 2023 at 3:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 10:11pm
Would depend on HP and RPM you're running. In the days of old,there were plenty of HOT pullers before  the counter weighted crank appeared. Just sayin
