Question for Steve at BnB
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Topic: Question for Steve at BnB
    Posted: 29 Oct 2023 at 1:43pm
Steve. Working on a Hercules 3 cylinder gas engine in an Oliver Crawler. Delco distributor number 1111897. Doing they make a Pertronix kit for it? Will one for a 6 cylinder work?
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 6:10am
bump
1968 D15D,1962 D19D
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 7:55am
You could send Steve a direct email.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 8:35am
I dont know, but it appears this might work.. I would take the Pertronix part number--- - 4471131---  and e-mail them to confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2023 at 5:45pm
Hi Don!
Sorry, it's been a while since I been on the forum. Been busy with leave detail around the property.  That 1111897 Distributor was a weird one. I worked on one of those a looong time ago, and I think that's the Distributor they used a 6 cylinder cap on and had three towers blocked off. (?)  I went through the Pertronix catalog and didn't see it listed under 3 cylinder Oliver. I then checked by Distributor number and came up empty.  As Steve mentioned probably a call to Pertronix is in order to see what the Devil is available for that goofy Distributor.  Sorry, couldn't help ya on that one......... Unhappy
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2023 at 6:16am
You are correct on the cap, although that cap is long obsolete and now its is just a straight up 6 cylinder cap.
This whole thing has been a challenge to overhaul. That little 3 cylinder Herc is a good little motor, but it is long obsolete
1968 D15D,1962 D19D
