190xt position control
papa_t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papa_t Quote  Post ReplyReply Direct Link To This Post Topic: 190xt position control
    Posted: 22 Oct 2010 at 1:32pm
  I have a 190xt I bought used. It has been setting up for 4 years. I have everything working and running except position control. All linkage is correct as pictured in manual.
  any suggestions?
   papa_t
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 8:02pm
Do the levers move freely?
Another place to suspect is the pump section that supplies pressure for the mid inlet on the valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 9:46pm
Linkage is frozen under right side under fuel tank that runs from top of right lift arm to pivot above axel.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote papa_t Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 10:52am
 All linkage is moving freely and moves plunger at sensing valve, so I may have a pump problem. I will need to get a pressure and flow gage tool to check pump and valve settings.
    thanks papa_t
Post Options Post Options   Thanks (0) Thanks(0)   Quote papa_t Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 10:55am
If I have a pump problem, is it ok to try rebuilding pump or should replace it
  papa_t
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 4:43pm
Before you condemn the pump, manually push in the Traction Booster spool all the way with the engine rev'd up and see if it will even lift the hitch with the lift/lower lever in "hold"....no lift....probably pump problems. There's one piece of linkage under the fuel tank that used to flop over backwards and make the linkage inoperable....I used to install a 1/4" bolt/nut in an unused hole to keep that from happening.
