Cast iron fire rings from Mack |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
Topic: Cast iron fire rings from MackPosted: 25 Oct 2023 at 9:11am |
Does anyone know if Mack had provisions for some else to make his fire rings ?
Or is that specialty part gone with our friend . |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 25 Oct 2023 at 9:26am |
if you are referring to the fire rings for the 262 diesels, they were steel wire not cast as i bought a set. i doubt they will be available now that mack is gone
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
DrAllis
Posted: 25 Oct 2023 at 11:33am |
I've never seen what he used, but always assumed it was "Lacon" ring material. Basically a round wire of a certain diameter (thickness) cut and welded together at the tips to fit exactly where the A-C fire ring would go. If the original fire ring was say .080" in height, I'd suspect he was using .100" wire, so it would crush down to somewhere close to that .080". The thicker wire would help make up for the sleeve being sunk in the block. I do not know what size wire he was using.
Macon Rounds
Posted: 25 Oct 2023 at 1:37pm |
I am sure you are correct.
Not sure were I got the idea they were cast. I have a set here somewhere that I bought but haven't used.... i do remember them being round and welded. Finding them is another chore. I moved 800 miles from Ga back to grandpa's farm in Pa. 2020 with most of my tractor stuff. Was very organized in Ga. not so much in Pa. 😀 |
CAL(KS)
Posted: 25 Oct 2023 at 1:54pm |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5124 |
Posted: 25 Oct 2023 at 2:25pm |
I have fire rings made for lots of different applications, and did have some made for the 262, as well as the solid shim steel head gasket. They quit making their gaskets, so I kinda quit getting as many fire rings. Not sure what Mack was having them made to for dimensions. The ones I had made initially were .070" wire. Did have one customer who had several sleeves sunken in, and I ordered for him several different wire diameters based on his level of sinkage lol! That was a one off deal. So after that I have not messed with those too much. Mack gone may have to step back up lol! We truly lose an extreme wealth of knowledge when the older guys retire!
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8741 |
Posted: 25 Oct 2023 at 5:09pm |
I have a set of Mack's fire rings for 262 diesel. Better not lose them. Darrel
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8686 |
Posted: 25 Oct 2023 at 10:15pm |
There are places that make them
