Front tire pressure
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Topic: Front tire pressure
    Posted: 22 Oct 2010 at 10:22am
How much air should you run in a 6.00 x 16 front tire. ( 3 rib ) No info on my sidewalls.
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 10:40am
I'd say 28 to 32 psi
Wink
I am a Russian Bot
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 11:03am
With a loader we run up to 40psi but otherwise about 30
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 11:09am
Depends on ply rating.  4 ply 32 psi max, 6 ply up to 40 with a loader, otherwise 32.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 3:40pm
I keep just enough in mine to hold the tractor up, maybe about 10 psi. I don't have a loader. Softer tires cushion some of the bumps.
