New power cord for my mig,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: New power cord for my mig,,,,,
    Posted: 21 Oct 2023 at 9:57pm
  I'm wanting to replace the power cord on my Lincoln 175 Mig welder. When I bought the machine It had had a BIG bulky hard to move power cord and just plain a good eyesore,,,!!  Do not know what wire size it now has  but the OD on the power cord is 1 1/4" OD and very stiff to move around!
 I would like to install some smaller in size power cord that is more flexible.
 Any thoughts on this,,,,??
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 10:41pm
Use #6AWG SOOW cord for your input cord up to about 50' length for that size welding machine. Any smaller and you'll lose some top end performance and possibly weld quality. You could downsize to #8AWG but if you weld much over 125A the input cord will begin to warm up.
My assumptions are your welder is a 60% duty cycle single phase unit. If a 20% duty cycle unit, I wouldn't be afraid to downsize to #8AWG for the power cable as the welder will shut down before the input cable warms.
There are reasons that original cable is so heavy and it's not because the manufacturer wants to ensure they spend a bunch of money building the machine.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 11:14pm
That welder only has a 20 - 25 amp input... But they "recommended" a 50 amp plug and wire when new... Thats a little odd..  An 8 gauge wire would be 40 amps. That should be fine as Codger says as long as the cord is not 50 ft long or your using 175 amps continuously !!
I just bought a "high flexible cable" for a smaller welder a month ago.. Bought over the internet at Home Depot of all places... see if i can find a link to a " flexible #8"..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 11:20pm
here is a 25 ft cord on AMAZON that already has the plug on the end !!!  8 gauge..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 11:26pm
The above cord is a STW which i think is a plastic cover.. Might get hard when COLD or 20 years old.... the SOOW that Codger talked about is rubber and should last forever.. Cost a little more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 11:28pm
SOOW is a very heavy EPDM jacket and if the welder in question is older, very well could be equipped with this. SJO is also very flexible but does not offer near the durability, or longevity of the SOOW but it is much lighter in physical weight. It is a PVC jacketed wire. SJO is typically what your outdoor extension cords are made from and we know how well that stands up to sunlight. Used continuously indoors wouldn't be a problem till a weld berry is dropped upon it.....
SJOW cable is smaller/lighter than SOOW and is weather rather for outdoor use, (the "W" stands for "weather, or outdoor" use) but is a bit difficult to source and used to be expensive.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2023 at 10:29pm
Most units can also go with a reduced size ground wire . like 2 #6 and 1 #8
Now many units now use the 4 prong plug rather than the old 50 Amp range plug .
 Ran into that back in 90's when wife replaced her large studio KILN for ceramics . Had to change receptacles and buy a power cord .
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 7:20pm
well Joe....if'n you gots 2 short cords...you can stand between them, wet both yer fingers and grab the ends of each cord for a positive connection! uh....maybe you should wear a jock strap too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 8:23pm
 You Know,,Shameless,,,I really do believe you like me,,,ya just don't want to admit it,,,,,LOLWink
 But,,,but,,,what do I do with theWinkWink third lead,,,,??
Edited by desertjoe - 29 Oct 2023 at 8:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 11:18pm
uh...don't spit before putting it in yer mouth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 3:00am
 AWwwww and here I thought you wanted me to stick it into,,,,,,MMmmm,,,never mind,,,,!!Big smileBig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 6:20am
OK, I don't understand having a 'reduced ground wire' size.
 If NEEDS to be same size as the power leads otherwise when machine shorts out, the smaller ground wire will fry and open up.
house 14/2 has 14 gauge ground wire.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 6:34am
You are allowed to downsize one size on the grounds. I looked into this when built my building.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 7:22am
I have a Rubber Sheathed 240v cable, very flexible and at 20' a great deal of Handy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 3:00am
Joe....check wally world in the camper area, think they have 50 ft cables...can't remember the price tho.
This page was generated in 0.293 seconds.
