What chain do I have here ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: What chain do I have here ?
    Posted: 20 Oct 2023 at 12:50pm
Parts IPC does not indicate size.
Side plates on chain says 50 but data on 50's does not match what I have.
This is stamped on chain
?orsE
or
MorsE
Here is data on my chain.
Pitch.     .625
Roller dia .400
Distance between inner plates .375
Side plate thickness .095
Edited by Macon Rounds - 20 Oct 2023 at 1:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 12:52pm
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 1:10pm
Usually when a chain fits like that, the chain or sprockets or both are worn out. Remove it and lay it on a flat surface next to a new chain with same no. of links and measure the length of each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 1:18pm
Chain is far from worn out.
Picker in shop for lub and adjustments.
Lots of rub blocks on this machine. So after first few runs with rusty old chain they all need adjusted.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 1:56pm
I don’t think your sprocket looks that bad, like you said just needs a little snugging.
Number 50 W or heavy maybe? Should be able to look up a chain table easy enough. I’m not at work or I’d have one a foot from my left hand.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 2:37pm
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 3:08pm
Your dimensions match the spec's of #50H roller chain. The 'H' stands for 'heavy'. Most manufacturers offer standard and 'heavy' roller chain - the difference being the sidebar thickness and thus tensile strength. In these cases, the number is typically followed by an 'H'.
As you provably know, the first digit represents pitch in eighths of an inch (or first two digits if a three-digit chain). So #50 = 5/8" pitch = 0.625" as you posted. #120 = 12/8" pitch, etc. If it's preceded by a '20' for a two digit chain or '2' or three digit chain, it's double pitch. Ex. 2050 roller chain = 2 X 5/8" = 1.25" pitch. Double-pitch is used on a lot of farm equipment to save on cost (half as many links/pins/rollers to make), and is sometimes used in industrial equipment on sprockets with odd numbers of teeth so it engages a different set of teeth each revolution and thus halves the wear on sprocket teeth (called a 'hunting tooth' design).
Roller chain is available in standard roller or high roller. Standard roller diameter for #50 is 0.4".
Roller width (between side bars) for #50 is 0.375".
Only difference between yours and standard is side-bar thickness. Standard is 0.08", but heavy is 0.095" (what you have).
Edited by DanielW - 20 Oct 2023 at 3:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 3:12pm
I should also add, standard roller chain (not heavy) will work on your sprockets just fine. Unless it's a really, really heavy-duty application I don't think I'd worry about trying to find heavy. We use it at work on equipment we make that's in service for 10 hours a shift, 2 shifts a day, 365 days a year. I doubt any Allis equipment is seeing that much use. Only time I buy heavy at home is when I have to weld lugs or attachments to the links.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 4:28pm
GREAT information fellas !
Figures I would look up the only chart with a misprint.
This chart has #50 chain pitch is .525 Grrrrrr !!!
Chain on order now. :-)
Edited by Macon Rounds - 20 Oct 2023 at 4:29pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 5:15am
Think the .525 is a typo.  Everything else I see on Google says 5/8 or .625.
AaronSEIA
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2023 at 7:55am
Divide by 80 to get the pitch. 60/80 is .75” 40/80 is .50”, etc. works for any chain ending in “0”. If it starts with a ‘20’ I.e. ‘2060’ then it’s double length.
