CA Solid Push Rods?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Solid Push Rods?
    Posted: 17 Oct 2023 at 3:33pm
Steiner sent incorrect push rods (part number mismatch).  They were 9.2 inches long and had a drilled oil hole.  The replacements they plan to send are 9.8 inches long but also still has an oil passage.  Must these be solid or is drilled ok?
Edit:  Correct for a 1952 CA is solid rods/tubes of 9.828 inches in length.
Edited by dfwallis - 17 Oct 2023 at 3:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 3:36pm
im not sure there is enough adjustment in the rocker arm screw to get an extra 1/2 inch of length on the rod... ??
or are you saying the 9.2 was SHORT and the NEW 9.8 are correct, but have a hole ?  I dont see that the HOLE is going to hurt you any with a splash lube top end.
Edited by steve(ill) - 17 Oct 2023 at 3:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 3:42pm
The correct length is 9.8 for the CA.  The 9.2 length is for D10 and that series of engines.  They sent the D10 rods in the CA package (labeled as CA PN).
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 3:44pm
you look at the oil line feeding the top end. It is not very big.. You dont get a lot of flow.. It dont take much.. A few drops on the rocker now and then is adequate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 6:52pm
I have been working the B,C,CA AC engines for nearly 60 years now, I've yet to see one that had drilled pushrods. Stiner sold you "who knows what". There is no need for them to be drilled as there is nothing that could put oil into them. I have seen solid 1 piece, solid 2 piece and tube type ones. If you were to come by my place needing some, I'd give you a hand full. I put HD tube type ones that I remake from Dodge 225 engines in all the Hi-Performance BE/CE 138/149/160 engines I build
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 6:58pm
Nearly every seller of new pushrods sells the same product.  A few have a similar one that is slightly smaller in diameter.  I don't have enough info about them to know whether the contact surface is the correct curvature.  If they don't fit, then I might punt and get some used.  Two of the original are not bent, the other 6 are bent to varying degrees.  None are bent really bad.  If I have to straighten them, I can, but would prefer nice new straight ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 7:04pm
Straightening them for a farm tractor is not a problem, if only bowed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 7:26pm
How many do you need
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 7:54pm
The new ones are on the way.  If I decide to go used, I could need up to 6 unless I can straighten the old ones to my liking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 8:03pm
They’re still available through agco. We also have nos
207426
