What is realistic mileage for a Chevy 6.0
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Topic: What is realistic mileage for a Chevy 6.0
    Posted: 16 Oct 2023 at 7:30am
it's in a 2002 Suburban, gas guage does not work, so we trip the odometer and put gas in every 200 miles. Mechanic says we will have to change the instrument panel which includes the odometer to get the gages to work, oil pressure gage has showed bad ever since we owned it, 6 or 7 years and 50K miles ago, he said pressure is fine, just gage. I don't want to have to mess with sending off for .... o think we will keep doing what we are doing until it all quits.
recalibrating odometer to get everything to work
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 7:53am
wow I googled...2002 suburban instrument cluster, got 2 MILLION hits....
options...
1)  I'd get another cluster from a you-pick-it-place.....
2) I'd also remove cluster and resolder the main connectors....
3) you can buy refurbed units for $200-250
4) keep full gas can in  trunk...
as for mileage...
fill tank to first 'click' at a pump, drive say 200 miles, refill at SAME pumo, 1st click. That will be a pretty good guage of MPG..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 8:59am
well, if you drive 200 miles and then put in 20 gallons of gas... You can figure your getting 10 MPG... If you got a 30 gallon tank, you could probably get another 50 miles to the station.. I would not push it to the limit and try to run 29 gallons out of a 30 gallon tank !! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 9:55am
or..
loan it to my brother who never puts gas INTO my rides....Angry
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 11:19am
Those instrument clusters are fragile but repair easily. Minute stress cracks in the solder runs can be found easily with a lighted magnifying glass.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 1:24pm
Flat level ground 70 mph, 14mpg.
Pulling trailer with kubota side by side 70 mph 12 mpg
Pulling 20ft camper to Utah 70 mph ,8 mpg
2005 Chevy hd with 6.0 gasser
Edited by Pat the Plumber CIL - 17 Oct 2023 at 8:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 2:01pm
Sounds like my KW Pat!!!, Only it will not get 14 no load!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 2:17pm
I don’t keep track but my little thing that show’s average mileage says 9.9. None of my dash works anymore. I’m hoping to get it fixed. Iv been told about half dozen different fixes though. One guy said there’s some kinda kit you can get that replaces resisters or something, he said it’s simple. Was going to try that first. But the little info thing works so I use the range for knowing when I need gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 2:42pm
Those sheet circuits always were a joke to deal with.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 6:55pm
Mines averaged 12 mpg for the last 650000 miles.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 8:02pm
A lot depends on rear axle ratio
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 8:09am
Do you have too many zeros? That looks more like Big Truck  miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 11:13am
10 to 12 MPG is the best I have done with the 6.0
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 7:43pm
I concur, 10 to 12 mpg is all I could get too.  It is a strong engine though for sure. I traded with 200,000 miles and never had an issue with the 6.0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 7:46pm
ours has 326 on it
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 8:23pm
My ‘95 Suburban w/TBI has averaged 12-13 mpg over it’s lifetime(211,000 mi). IIRC, 1995 was the last year for the TBI, then after EFI. 40 gallon fuel tank, if I’m not mistaken. 350 cu inch.
Edited by Lars(wi) - 18 Oct 2023 at 8:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 9:13pm
I had two 6.0 engines in 3/4 ton Chevy pickup trucks. 12mpg was on a good day and empty. No problems over my tenure with them and very reliable.
That's All Folks!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 11:05pm
he who runs on the bottom half of the tank all the time will have more fuel pump failure than guys that run on the top half all the time
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 6:11am
This is true and proven over many vehicles as the modern fuel tank is also the cooling medium for the pumping unit.
Pumps have a longer service life when they are kept cooler than warm as is the scenario referenced.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 9:27am
No sir that is actual mileage.
Had two water pumps and intake gaskets once.
Transmission rebuilt at around 330000.
She rattles on cool mornings but still runs strong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 1:02am
I also have an '02 burb, so far everything on the dash works, the 4x4 quit but still drives fine, I use it for a farm truck mostly, do take long drives sometimes. has over 150,000 miles on it now. they're not really worth anything for a trade in or to sell it, i'll keep it and drive it til one of us dies off! long drives we take the old lady's.....ooooops.....I mean the loving wifes Burb, it's a 2015. I don't really care on the mileage, it's better than walking! it heats good in winter and the a/c blows cold in summer, what more could a guy ask for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 3:27pm
Is it push button 4x4?
If so the switches are prone to fail.
Can be had cheap online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 11:14pm
yeah Thad, it is push button, and it has been replaced, but that wasn't the problem, so I had a new (whatcha ma call it) installed in the transfer case, but something is wrong or broke inside the case and that new part won't fix it either. it still drives fine...just no 4x4. I can do without that as I own 7 other 4x4's I can use. i'll just drive this one til it dies or rusts away! lots of good parts on it yet in case I buy another like it.
This page was generated in 0.520 seconds.
