rear lift capacity wd45 vs. series 1 d17 |
Post Reply ![]() |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3926 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Oct 2023 at 8:54pm |
will the series 1 d17 lift anymore weight than the wd 45 what about the series 4
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22002 |
Series 4 will lift more than both the others. D17 will lift more than a WD45. THIS ASSUMES EACH TRACTORS HYD PUMP IS SET CORRECTLY FOR PRESSURE.
just started useing a bigger triple k digger thats got one more row of danish harrows and a harrow bar on the back plus it has wings i can pull it with the wd45 but i cannot lift it if i am idleing i can get it up it hits the relief, i dont have pressure gauge on that tractor hope fully i will have the d17 done by spring
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6080 |
My D17 will outlift my WD45 hands down...
The first two generations of the D-17 had a slightly smaller diameter ram than the series 3 models. These all used the high pressure 3700 psi piston pump. The series 4 went to the "live" low pressure 2,200 psi system, so they had to go with two external cylinders and in the end they were the most powerful of them all.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3569 |
Here’s some previous AC forum posts about the subject.
https://www.allischalmers.com/forum/wd45-lifting-arms-cap_topic175728.html https://www.allischalmers.com/forum/d17-lift-capacity_topic163554.html%20 Edited by AC7060IL - 18 Oct 2023 at 7:06am |
this wd45 has a f11 loader , rear tires with calcuim am and three weights on each rear wheel on it and it makes the front light , on my wd it just lifts the front end off the ground no extra weights
Post Reply ![]() |
