Experience with mounted corn picker ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Experience with mounted corn picker ?
    Posted: 14 Oct 2023 at 5:43pm
Anyone having experience with mounted corn picker operations please advise .
Or share your experience.
Or PM and we can exchange phone numbers.
I will grease all the cogs and gears, lubricate all thr chains and verify everything is free and turning before I install the shoot/elevator.
I am only vagly familiar with corn picker operation so this will most likely be a steep learning curve....In both operation and maintenance.
Edited by Macon Rounds - 14 Oct 2023 at 6:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 6:56pm
What model picker is that Benny? I will see if my friend Kenny has a manual for it. Have a lot of pull behind picker hours but not a mounted picker. I would say it will be very dusty so a mask would be helpful. You will be up close and personal to see what’s going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 9:11pm
Looks to be the latest and greatest mounted model with the tall sides!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 5:48am
Link to Operators Manual for a Model 17 Mounted Picker
G
https://www.ebay.com/itm/204370631693?hash=item2f95705c0d:g:qtgAAOSwTDhiSQBC&amdata=enc%3AAQAIAAAA8PChSzTFrzuIl%2BNX6ESKgaAoKKOSyLQnqEXnhg5bf6izc8jKZoR5ghwqYHV%2FngYUlQ86QGzgP12DIxWVWRYPgAHTe4uSBN%2B9cg91gFWK0wSx5C17hslNpa5X5hPGvrYRk1KRsEqJj6xuEZhex2Xrl4D1d99zEcRiDthJFjK7qvLiqx13%2F
WGqWYEW4422pS18jE%2FhAXgcMZJ0FrAaOrFpyxpwmEJe7wOLbeHS%2FWWfDT6sjakY49bTpVM5kBNnNjfAeFR3A%2B8ZP8jmXQjKDfCL74JVCQsaGG1A5L2%2FCSXQGP1RuXyO4eeJuXOvq1VTN6HDug%3D%3D%7Ctkp%3ABFBMgKv4ruZi
You Tube Video Allis D-17 picking corn with a Model 190 Picker
https://www.youtube.com/watch?v=AfMD4ypTaZQ
Link to Allis Model 90 Brochure:
https://www.ebay.com/itm/314111685371?hash=item492283f2fb:g:m2wAAOSwOLRi~Xar&amdata=enc%3AAQAIAAAA0BhX56kbfcSjs5V%2B4LtyRaWAVGvUsWh%2FFzyhvFsB8scjzmbnKY2CuVdUavIpa4%2BA1rBRNpTUH4X3nNzXu2u4oagTHczEcYcAdfmfE3WIJ2IS4j625y4jVOvNG2frAvw3adi%2Bc3ewHU2HlL2Jt%2BZXZdyCdWu84Y7X0XdTlIPQlvjLR65eUKnDzHAcnt2mNixWcCzJnLwirR%2BeILLs8tWzS8ZnE%2BT4DMuOm%2BYMSTtaM7HEApB5Ietew1uWGcGSGJ%2F3E2Ofxth5nieKTT070Op%2FMkY%3D%7Ctkp%3ABk9SR4Kr-K7mYg
Link to Manual on ebay:
Allis Model 190 Operators Instructions.
https://www.ebay.com/itm/385276080819?hash=item59b43e72b3:g:kxMAAOSwxXZjjjSA&amdata=enc%3AAQAIAAABAPIRnCblEosA3hYgkI8wgskm20ha9xGPb26xZtCwYbJpmlUOBdsPV1EyzXwtSZ2tAHpogJBZBxi%2BbDGwn%2B07oSibeszjfgSMEAucIbdlxeZsfY%2F7sHqMCNk%2FxYdJXja9IMD3gwxShkdZRlk%2B99dFmQ5My1sBe1cC9GRtWMm8sTR6cQhKjKmoCHBkzcDYKuKqcg%2FFWj6yShpcfQhZqNTbXtXfnYdRWkrzEWET2RBEFYYpyBj1iYGqkVl29XHSHPv5OqRsDtOKZgBhi%2FhWtFeEU38%2BM1NGnwt01K4whl2wM5A1H4W%2BAjlaCR8dCIy7k3Da6DpIma%2B6J9%2B0Vol1mVmiBLk%3D%7Ctkp%3ABk9SR8Dn7rfmYg
Edited by Gary - 15 Oct 2023 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 11:36am
Thanks Fellas
Not sure what model it is...
Not sure how to identify ?
I know they made 150, 170, 190 but figured the whey went with the D15, D17, D19.
Still trying to educate myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 12:02pm
I Figured the only difference would be the mounting hardware.
Edited by Macon Rounds - 15 Oct 2023 at 12:22pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 1:53pm
Perhaps ordering these 3G Manuals would answer your question:
Model 150 and 170 Operators
www.ebay.com/itm/155368203966
Model 190 Operators Manual
Allis Parts Catalog Models 150, 170, and 190
https://www.ebay.com/itm/204358616340
G
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 6:28pm
Video how it goes when you are testing!
My only experience driving a mounted picker was as a ten year old steering the front wheels of our Oliver 880 and mounted New Idea picker with locked up transmission dragged backward as the hitch was chained to our IH 806 to lift the Oliver rear wheels. My father was helping pick corn for the neighbors who didn't have or their picker was broken down. The Oliver and picker were less than fifteen years old at the time. Apparently the trans gears did that on those tractors. It was an all day adventure getting that tractor home.
Make sure to put a bug screen over the radiator for the dust and corn debris. Some of the tractors had engine side shields to protect from dust catching fire.
Mounted pickers are great for opening up fields.
YouTube channel Geirok Farms has some mounted picker install, setup, and running. Modern combine setup and adjustment videos on Calmer YouTube channel.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 7:13pm
Sweet picker dude!
I have a model 33 on WD tractor
Galatians 5:22-24
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 9:37pm
I have run a 17 picker on a D17, a 227 JD picker on my WD45, and pull type New Idea pickers. Start out slow and easy. Make sure all grease fittings "take grease" all chains are oiled. Sit on the seat, get used to the noise it makes. As I said, start out slow and listen to the noise she makes when she's working. A lot of time, they will tell you when something starts to wrong.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 11:41pm
Make sure all grease zerks take grease. BUT slip clutches that have a zerk get 1 pump only with a hand pump gun.
 First 4 or 5 years I farmed used my M farmall w/ 2M picker (the 1 with center snoot that turned with the steering). 1 6x10' wagon & luckily it had an extendable tongue & hoist for unloading. This is when I learned to NOT over grease a slip clutch, I it did even after dad and grandpa warned me not to.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 7:31am
That is a good looking unit! Best of luck with it. I don't believe it's a 190 as I have one and I don't see a couple things.
I was in Northern Ill Friday and saw a mounted picker on a WD45 and stop by and talked to the fellow for a few minutes.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 10:12pm
Very nice!  Its a model 150 picker, very rare.  Im betting its all a D15 wants.
Make sure the stripper plates are adjusted correctly.  A screen over the radiator is necessary.  A manual would be good for you to get the basic adjustments.
We have ran my 190 a number of times.  PM me if you want to talk.  Ill send you my phone number.
Jim
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 7:17am
Is that picker on a D-15 or D-17? I had a 150 picker on a WD-45 years ago and in good corn, first gear was too fast! That style picker was a national corn picking champion back in its day.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 11:48am
D 15
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 3:45pm
What are the basic differences between 150, 170, 190 pickers ????
Husking beds, chaff blower ????
I'm a D17 guy and really wanted one on a D17 but this on came avaliable.
Just pulled it in garage for service today...
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 4:48pm
Dad had a 190 on a D 17 was an all day process to mount/unmount it.
Life is tough,but it's tougher when you're stupid. - John Wayne
Ac7040d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ac7040d Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2023 at 6:24pm
I have a 150 picker like yours on a D15. The D15 handles it okay. I use it to pick a few acres of popcorn every other year. Only disadvantage is the high sides, you almost always need to stand to turn. Mine does a good job.
Post Options Post Options   Thanks (1) Thanks(1)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 9:34am
Initially when the 150 and 170 pickers came out they didnt have the flappers in the throat to help the material through.  As far as I know there was an update kit to add these to the pickers.  I have never seen one without them.  I have also read that the 150s and 170s only had 2 gathering chains but I think they all have three?  Id like to find the bulletin for those updates but have yet to see one.  I have seen on a few 170s and 150s you can see the model number decal behind the shields on the left hand side.  When the updates were installed those decals were covered up.  I have never seen a model decal on a 190.
As far as differences, the 190 had some updates to the stalk extractor shields on the top and I think the husking bed was a little different.  The cylinder mount is different. The cleaning fan was in a different location on the 190s. The 150 was designed to be mounted on the D14 and D15 tractors.  Very few were built.  The 170 was meant for the D17 and the 190 could be mounted on a WD, WD45, D17 and D19.  If my memory is correct they built 250 model 150s, 750 170s and 1000 190s.
I do have a parts 190 machine if anyone needs anything.
Jim
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 1:19pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 12:28pm
I"m sure it's dirty and dusty and I've alwasy wanted to drive one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 12:58pm
Hey JimIA
sent you a PM a few days ago.
Call me please.
