8070 problem
Slaughter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slaughter Quote  Post ReplyReply Direct Link To This Post Topic: 8070 problem
    Posted: 21 Oct 2010 at 8:08pm
I have a 8070 with 5000 hrs on it.   I haave been using it on the grain cart this fall .    All fall it has been plutting  out a lot of smoke and has lost  power. It has a new turbo and  the pump and injectors  rebuilt in the last year.   Starts good but has no low end power   Any help would be helpful.
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:14pm
if it is black smoke it is not getting enough air check for a boost pressure leak at manifold or crossover tube, do you here a whistle at all? also check for restricted air flow maybe air cleaner . if it is white smoke it is unburned fuel as maybe injector tip blown off or timing or anything to do with low compression on a cylinder, what color is the smoke?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:14pm
Is the air filter clean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:46pm
Blown intake gasket between the intercooler and the cylinder head....fails just above the starter usually.
ACB110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACB110 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2010 at 9:45pm
Just replaced our fuel injector pump on our 8070 the advance/retard timing mech. went bad only 1700 hrs. on it.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 6:34am
As Dr says, or check for any plugs in manifold that may have fallen out. Have seen this several times. Put a boost gauge in the manifold and check it. This tractor sounds like it isn't getting boost. Then you need to find out where it is escaping to. good luck, Ed.
