D17 hydraulics
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Topic: D17 hydraulics
    Posted: 09 Oct 2023 at 6:23pm
When raking hay I had to keep putting oil in hydraulic. We took the lift arm housing off but the hose and cylinder appear to be good. Any suggestions. Thanks
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 7:24pm
Check your transmission dipstick. If it isn't leaking out somewhere, it is probably going in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 8:06pm
Before going to all the work to remove the lift arm housing, you must verify the missing oil is actually going into the transmission. So, now you need to replace the hose and install new seals in the cylinder and put it back together, hoping that fixes it. If the missing oil isn't going into the transmission, is the Power Director clutch overfull ?? WHAT AGE IS THIS TRACTOR ??? series 3 ?? or older ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 7:25pm
Its a series 2. The transmission was over full thats why I figured it was the hose.I'll replace everything and out it back together.Thanks for the replies
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 8:04pm
Then, you will be OK fine. ALWAYS replace hose AND hyd cylinder seals while apart.
This page was generated in 0.067 seconds.
