L3 steering issues
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: L3 steering issues
    Posted: 08 Oct 2023 at 1:57pm
I have a L3 sn26576
I had low hydraulicpressure issues and mistakenly removed a plug for the priority valve looking for the pressure relief. Now i have no power steering. Ive removed and installed the priority valve SEVERAL times and cant find anything wrong with it. The steering hand valve in the cab only has 2 lines which controls a steering valve at rear of the combine. If anyone has had an issue like this id love to know how you overcame it
Thanks
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 8:40am
If the fluid level is sufficient, check the belt tension for the hydraulic pump to make sure it's alright.
Have you lost the other hydraulics as well? Will the header/feeder house lift, or auger swing?
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 12:31pm
Its only steering. I dont think theres a problem with the belt because if i lift the feeder house all the way up and hold the button it loads the engine. All other hydraulics work fine. Its either the priority valve or the steering valve i think but I cant figure out how to test either
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 2:51pm
Probably is local to the steering then, I've never heard of a steering valve acting up, likely a problem elsewhere in the system.
This issue sounds familiar, like within the last year someone else had the same issue. Try a search on priority valve see what comes up.
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 3:57pm
Thanks. Ill do that
1984 80780
1957 D14
616 tractor
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 9:37pm
Check the flow divider in the end of the pump = the first 3  maybe more - gallons goes to steering and the rest goes to the hyd section.
This page was generated in 0.073 seconds.
