F2 rock door concave for corn and beans |
Jason n
Topic: F2 rock door concave for corn and beansPosted: 07 Oct 2023 at 5:24pm |
Can I let the concave on the rock door of my f2 for corn and soybeans instead of removing it for corn and replacing it for soybeans??? What are any negatives of having it on the door all the time?
DrAllis
Posted: 07 Oct 2023 at 6:50pm |
Only way I ever ran an F-series was 1-3-5 which means 1 is on the door for everything.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3583 |
Posted: 07 Oct 2023 at 11:30pm |
Which cylinder rasp bars are installed in your F2?
-Standard 1/4” rib spacing? -Or Aggressive 1/2” rib spacing? |
Jason n
Posted: 08 Oct 2023 at 12:50am |
I believe they are the standard rasp bars
AC7060IL
Posted: 08 Oct 2023 at 7:45am |
Standard rasp bar is kind-of its “negative” that you ask about. It can thresh ok. But agressive rasp bars allow far greater capacities.
Anyway, with standard rasp bars try placing a “well worn” (1/2 as tall?) concave in door (#1 position) & leave it for all crops(corn,soy,cereal, etc). F2 offers 6 concave positions. Like DrAllis says, use 1,3,5. 1,3,5 usually offers best results? More importantly, what’s your F2’s other settings that you use for its cylinder heights & cylinder speeds per crop?? Edited by AC7060IL - 16 Oct 2023 at 1:30am |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8686 |
Posted: 09 Oct 2023 at 12:42pm |
The claim was that bar on door in corn causes extra vibration and wear on latch. Have done both and have no data to support claims either way. Maybe after thousands of acres?
Jason n
Posted: 10 Oct 2023 at 5:09pm |
I'm running 20" pulley as fast as it goes (tach doesn't work) clearance at 1/4" later in afternoon I can slow cylinder down as it starts cracking beans
