Who owns an r40?
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: Who owns an r40?
    Posted: 21 Oct 2010 at 6:35pm
How many people on here own an r40? Going to look at a combine on saturday, and noticed the dealer also has an r40. I've been told they are good combines in beans, but aren't great for corn. Is this true? And can they handle a 6 row head in 175 bu/ac corn?
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 6:41pm
Can't say about an R 40, but I have an R 50 and it handles 6-30's easy,  16 foot flex easy, can't think a 40 would be much different just somewhat less "grunt".
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 6:55pm
Is there any difference in seperator area between the two or is it mostly hp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 7:18pm
Rated engine power.   My 50 will "run out of head" before running out of capacity.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 5:45am
My uncle has an orange stripe R40 and really likes it. He runs a 15 foot bean head and I think a 6-30 corn head. Why can't I remember what corn head he has? Better go visit before he's finished combining.
Wink
I am a Russian Bot
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 10:09am
I had a R50, traded to a R52 the first year they came were made (same as R50 but different cab).  The R40 is the same combine just less power.  You will have no trouble with the combine itself with the power it has.  I have a 8 30 head on the 52 and am real happy with this arrangement.  It gives me a lot better cleaning job as I am able to keep the combine full all the time at about 3 mph in 180 bu/acre corn.  A 20' flex head in 50 to 60 bu/acre beans no problem at 4 mph or more.  If you get one that has a low wire concave corn cob plugging can be a problem in the concave in some varieties and not in others.  The high wire concave does not have this problem.  The low wire concave is much more desirable if you do mostly small grains and beans.  I am mostly corn with 200 acres of beans and have (my Dad's combine)  an M2 for my rye and oats/wheat (about 100 acres total), and have put a high wire concave in my R52.  The R models with the Deutz engine have the best fuel economy of all the rotaries that I have run.  The Deutz engine is noisy when you are outside the combine but quite quiet in the cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 5:24pm
How do you tell the difference between a high and low wire
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 7:07pm
I doubt if you find any R40 with the "high-wire" concave because they didn't start making them until after the R40's were out of production. Don't worry about that feature, it will work fine in corn/soybeans if you remove every other wire from the rear of the concave and the seperator grate. Doesn't cost any money, just a couple hrs of your time. An R40 is a really nice 4-6 row machine....not big, but will do an excellent job if in good shape and adjusted properly.
