L59 Blade Bolts Stuck
bisenberger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bisenberger Quote  Post ReplyReply Direct Link To This Post Topic: L59 Blade Bolts Stuck
    Posted: 06 Oct 2023 at 3:45pm
I have tried all the things from an old post about getting the blades loose on a Woods L59.  My compressor only gets up to 120 lbs and my 1/2 inch impact couldn't brake the bolts loose.
Any suggestions
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 3:46pm
Right or left hand threads????
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 4:14pm
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 4:20pm
They are left hand threads on ge blade spindles.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 4:28pm
Take a breaker bar and maybe put a pipe handle extension on it. I've had that work if the impact wrench won't. And as said reverse threads. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 5:21pm
Turn the mower on its back, stick a 2x4 under the blade to act as a stop,  big breaker bar, as stated, and righty loosey!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bisenberger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 5:32pm
Nevermine.  I put a jack under my 3/4 break over and added a long cheater pipe and got them loose.  I also made a piece of tubing out of angle iron to slide over the blade to lock it again the housing since one of my blades was broken.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bisenberger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 5:34pm
Thanks.  I didn't see the responses until I sent my message
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 7:31pm
I’ve got 3 Woods mowers. 2 L 306’s and 1 L59. All 3 have left hand spindle threads. I was under the impression that all L series mowers had left hand spindle threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 8:29pm
I use my Milwaukee 1/2” impact gun to get them off. I wish they would have put a sticker on the deck notating the rotation of the bolts.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 5:10am
I think my L-306 does have a sticker indicating left hand threads. It's been a darn good mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2023 at 11:18am
If it doesn’t have a sticker just write it on top of the deck with a permanent marker. I also wrote the size socket it takes for the spindle nut.
