WD 45 with Quick-Change Front-End, PS, AC500
Message Reverse Sort Order
Matt WI WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt WI WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 with Quick-Change Front-End, PS, AC500
    Posted: 06 Oct 2023 at 6:16am
Nice tractor with power steering and convertible front end option allows for swapping out wide and narrow fronts end with both adjustable wide and 2-wheel narrow included in this sale. (Also takes single wheel FE but I don't have one.)
Excellent sheet metal all around; steering wheel rubber smooth and 100% intact; 12v conversion; turf tires; curved shifter; front end loader with large and small trip buckets; rear 540 PTO; snap coupler; drawbar.  No three point. No ag tires.
Barn kept until two years ago.  Sand blasted and cold galvanized rear rims when I put turf tires on a few years back (minimal corrosion).  Could use new front rubber.
Running when I last used her two years ago but I need to change out the gas before firing up (that's why bucket is supported by 4x4s) and it's going to be a week or so before I can get to that but wanted to get it listed.
Has the usual oil leaks and rusted battery box. Needs alternator work or new wiring to alternator--was not keeping battery charged.  I rarely used it so just kept battery trickle charged.  One of the rear tires has a small leak.
Would make a nice working tractor or base unit for restoration.
Located in Milwaukee, WI and posted FB Marketplace this morning.
$3200 or best reasonable offer.
Edited by Matt WI WD45 - 06 Oct 2023 at 7:02am
Nuubie, WD45 Quick-change front-end, ps, AC500 front loader
