wd governor
3rdgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rdgeneration Quote  Post ReplyReply Direct Link To This Post Topic: wd governor
    Posted: 21 Oct 2010 at 6:00pm
I have a wd and the problem i am experiencing is when i fire it up it runs wide open. I shut the tractor down immediately because i know this is not right. I am assuming that there is a problem with the governor. Does anyone know the proper adjustments of the governor or have a diagram of how it should be assembled. I have searched different places on the internet but have not been able to find any info on how i should fix this problem. I would appreciate anyone knowledge.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 8:30pm
need to pull the gov sounds like the weights have broken off . this is what caused me to rev my puller above the rpm range I had it set for.  With the tractor off the throttle pulled wide open the carb should be wide open with the carb rod being about a half the hole long meaning the cross shaft needs to be pulled back towards the radiator to preload the gov. I think the measurement is a 32cnd
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 10:18pm
i have a govenor set up complete for sale,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 7:56am
Models WC-WD.WD45-WF
119. ADJUSTMENT. Adjust engine
speed by shortening or lengthening
control rod (5—Fig. AC52F) by using
set screw (4). To adjust linkage follow
procedure in paragraph 115.
Engine High Idle
(WC-WF) 1575 rpm
Engine High Idle
(WD-WD45) 1720 rpm
Engine Speed Loaded
(WC-WF) ., 1300 rpm
Engine Speed Loaded
(WD-WD45) 1400 rpm
120. OVERHAUL. To remove governor
weights unit, remove two nuts and
cap screw which retain magneto or
distributor bracket to engine and withdraw
bracket and shaft gear and
weights assembly as a single unit. The
weights and trust bearing can be renewed
at this time.
If shaft, gear, or bushings require
attention, the shaft should be removed
by bumping out the drive pin (28—
Fig. AC52G) on magneto equipped
models or remove distributor unit
drive gear on battery ignition models.
When bumping out the pin, be sure to
prevent bending of shaft by bucking
up same with a length of pipe introduced
through the opening in the bottom
of the magneto drive bracket.
On the WD, WC and WF gear (17)
is sold only with the shaft assembled,
not separately. To avoid damage to the
shaft when removing the gear, cool the
shaft while heating the gear. Shaft
should have .002 running clearance in
bushings.
It will be necessary to remove the
timing gear cover if the governor
throttle shaft and cross shaft are to be
overhauled. With cover removed, check
cross shaft bushings and, if necessary,
renew same. Check governor lever
spring eye holes jind contact surfaces.
Fig. AC52F--Models WC, WD. and WF engine governor iinicage installation. Engine speed
adiustment is made at pomt (4) by increasing or decreasing iengtfi of rod (5) Goveiior
linkage on WD and WD45 with battery ignition is similar.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 9:16am
i got a carb back from rebuilder and fired up and went wide open.  He changed the throttle plate inside and linkage was backwards and I didn't catch it.  Nothing like a new engine going sky high right away!!
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
