210 Clutch
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Topic: 210 Clutch
    Posted: 21 Oct 2010 at 5:21pm
How much horsepower will a stock 210 clutch hold? Reason is I just picked up a very cheap 210 with a blown engine and I have a good running 7080 engine sitting here. It wont be pulling plows and the like every day, be more like a planter type tractor but every now and then I'll probably use it for heavy work and want to make sure a stock clutch will hold or if I need to come up with something before I put this engine in. thanks!
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:50pm
A new stock clutch will hold 200 hp OK.......a worn stock clutch may not hold 100 hp depending on the condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 7:08pm
i planned on putting a new clutch in while I had it apart, I just wanted to make sure I wasent wasting my money.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 9:17pm
If you plan to pull it with more than 200 hp, you may as well put in the heavy duty 30 spring pulling clutch, and 8 pad HD disc. I got mine from Allied Precision in Pocahontas IA. Not much more than a reman stock unit, but a fairly stiff pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2010 at 10:30am
I might pull it sometime but it will still be used for field work and planting too. I'm not sure what I'm gonna do right now lol
