R 62 gauges getting hot
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: R 62 gauges getting hot
    Posted: 04 Oct 2023 at 8:15pm
Running the R62 in high 80's, cutting beans, the ac is ok but wont run you out of the cab. But when you put the back of your hand to any of the gauges, volt, water temp, oil pressure, they all feel hot to the touch. I ordered a new volt gauge ($91.00) because it was sporadic but the AGCO gauge didn't look anything like the original and terminal didn't match, looked like a $10 gauge from Orielleys. My son says its the old candescent bulbs creating to much heat. He is looking for an led retro fit. for the bulb
 Is there somthing else I need to be aware of.
Thanks
Len B MO
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:06am
My L3 gauges get pretty hot too, all of the ones you mentioned . guessing it's the lights as well.
Matt
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 9:35am
I just got a L3. I havent looked at the back of the guages yet but a lot ive seen have an incandasent bulb in them. They will get hot. It might be possible to change them led
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
