CA firing |
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2152 |
Topic: CA firingPosted: 03 Oct 2023 at 5:16pm |
Question, what am I missing. Put new points and plugs in my CA. Now on morning it will not start, the next it will start but sounds like it is not firing on all cylinders. Have re gapped the points several times. Still get the same results.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55288 |
Posted: 03 Oct 2023 at 7:00pm |
Got the firing order right?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 03 Oct 2023 at 7:20pm |
1-2-4-3 clockwise.
Trinity45
Posted: 04 Oct 2023 at 8:23am |
Marked the distributor before we took it off, but will check just in case.
steve(ill)
Posted: 04 Oct 2023 at 9:23am |
If the rotor wires are right... then i would relook at the POINT and CONDENSER wires and the terminal inside.. should be insulated and nothing touching ground.... and maybe try another condener.
Trinity45
Posted: 04 Oct 2023 at 9:32am |
I was thinking about picking up a new condenser. But wanted to make sure I was not missing anything. Some times the simplest things are what get you.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 04 Oct 2023 at 1:28pm |
Make sure the spark plugs didn't get fouled from trying to start the Tractor. Sometimes, if the plugs are wet or fouled enough, they won't fire. If you have Champion plugs in it, take them out, throw em' away and put a real set of plugs in it like NGK's or Autolites. Ya never know, it might just fire right up for ya.! I've seen it many, many times over the years whether its a car, truck or tractor..... HTH Steve@B&B
Trinity45
Posted: 04 Oct 2023 at 2:17pm |
Put new autolites in it when I put new points in it.
1955CA
Joined: 10 Sep 2018 Location: Ontario, Canada Points: 602 |
Posted: 04 Oct 2023 at 5:53pm |
I can't remember what brand plugs are in my CA. Anyone have the Autolite number handy? And where is the best place/brand to get new plug wires? And one last question, if I decide to stay with points and not convert to electronic, where is the best place/brand for a new coil just so I know everything is new again. Mine starts immediately and runs good other than it has a random, miss/pop at higher RPM's.
1955CA
Posted: 05 Oct 2023 at 8:15am |
Just looked. Steiners has everything I need.
Leon n/c AR.
Joined: 19 Mar 2013 Location: Heber Springs A Points: 177 |
Posted: 05 Oct 2023 at 9:12am |
Autolite # 303 for dist or 295 for mag best i remember. Leon
Steve in NJ
Thanks(1)
Posted: 05 Oct 2023 at 12:14pm |
For engines that have some time on them, and have a little oil control issue due to wear, I always suggest using the 295 Autolites. They are a little warmer. For fresh built engines, or low hour engines. the cooler 303's work fine. Steve@B&B
