Truss head screws?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Truss head screws?
    Posted: 02 Oct 2023 at 7:01pm
Where do you guys get the truss head screws with captive serrated lock washer at? They go on a D10-12 to hold grill shell to radiator and hook for hood latches. McMaster Carr does not have the correct ones.  Any help appreciated.Thanks , Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 8:47pm
Probably the same as I used on my D17, Sandy Lake had them a month ago when I put mine back together.
Edited by AC720Man - 02 Oct 2023 at 8:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 8:56pm
Tracy I was thinking of the 2 big flat head bolts for each side. I think your asking about the 4 bolts that are lower on the shroud. Brenda should have those also.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 9:08pm
A VERY LARGE Ace Hardware store,(Aurora and Peoria, IL) will have truss heads and washers in stock, but most hardware stores are too small to carry that kind of stock!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 9:08pm
Do they have a part number
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 8:09am
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 8:12am
Go back and read the original post. He obviously has found truss head screws. He wants the screw WITH the captive washer.
This page was generated in 0.053 seconds.
