Installing decals on my 1952 CA
52AllisCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 52AllisCA Quote  Post ReplyReply Direct Link To This Post Topic: Installing decals on my 1952 CA
    Posted: 02 Oct 2023 at 12:03pm
Hello everyone, i recently purchased a vinyl decal kit for my 52' CA and was curious about decal locations as far as how it came from the factory. Didn't see to much in the manual, so figured id best turn here to the forum. The " Allis chalmers" & "CA" decals i have applied already. Making a hinge with a line of tape method is how i went about applying them, and that worked out great. I've seen the pump adjustment chart applied to the battery box, the side of inner right fender, and next to the hydraulic control lever, just not sure which spot is correct from factory. Any help would be greatly appreciated. thanks again everyone, this forum/ community has been a tremendous help from day one.
S.R
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 12:22pm
I think the traction booster (or pump adjustment chart) decal goes on the battery box…
I don’t have one personally but my brother does…
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote 52AllisCA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 12:27pm
Thanks 55, I've definitely seen the majority of the pump chart decals on the battery box, and was kinda leaning that way as far as placement goes. Will see if many chime in here on the whereabouts to place that decal. Thanks for your feedback.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 12:28pm
All of the original CA tractors I have seen the hydraulic pump/ traction booster decal was on the right fender near the lift/lower lever.
 The WD-WD45 tractors had them on the right side of the battery box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 52AllisCA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 1:15pm
PaulB, Thanks man for your feedback on this decal location. I've seen a bunch on the battery box but just wasn't sold yet on weather or not they came from the factory like that. thanks Paul.
S.R
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 3:09pm
100% Original tractor here.  Hydraulic decal is on the inside of the left fender ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 52AllisCA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 3:48pm
Dseries4, very much appreciated, i thank you again for the pictures! exaclty what i was after. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 5:01pm
That makes sense because the lever/ adjusting screw is back there.
Thanks for correcting me…
My brothers is on the battery box but it’s not original…
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 6:14pm
That's where mine is on my 1955 CA
