220 engine
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 220 engine
    Posted: 30 Sep 2023 at 8:24pm
What is the most probable cause of broke pistons rings
and one burnt piston and being able to see the spray
pattern on top of 4 out of 6 pistons.
And can the crank be turned down without
worry of breakage and who does that work in
Indiana south of Indianapolis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 9:29pm
Sounds similar to the machine shop guys on utube
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 12:50pm
Bad design...all those 4 ring engines broke rings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 7:36pm
Well this tractor came from Iowa is all
I know about it right now and sat out in the weather
for an unknown amount of time to me..
The brakes are pretty much stuck and the p.t.o.
lever is also stuck..
I have it almost stripped down,still got the fuel tank
to remove but that's pretty much it..
It also didn't have a thermostat in it either
and a lot of calcium build up there and in the water pump...
The crank will have to be polished at the least but more than
likely turned....
